kante1603
Hello Joe,JoeMorris said:looks very good mate (although photos are now down!)
i have also bought a t bone 700 for this purpose. do you have any hints/particular issues i should look out for? Did you use the psu case that comes with the t bone?
thanks for the compliment.I´m really sorry that the photos are gone,I´ll try to upluad them as soon as possible (having an issue at imageshack at the moment-I´ve lost all(!!!) of my photographs there and I don´t know why.But they are all here on my drives so I can bring them back again,piece by piece which will be a lot of work and waiting :'(
O.K.,about the t-bone:There´s less space inside than for example in skylars mic body but it works pretty well.Max´s guide for assembly is very good and I did it the same way.
You will have to be carefull with the small screws-these are weak,so use a very good fitting screwdriver and take some patience.
The big cap I had was fitted with holders having mounting holes at its sides-it is easy to remove them and just file them.
Also I had to slightly widen up the mounting holes on the pcb (with a small drill)-easy job.
I especially like the tube because it is made of steel and easy to sand and laquer.It´s a good conductor from bottom to top and shielding is super-fine.
Don´t know what capsule you will use,I have a Thiersch.I had to use the smallest holder I was able to get;after that the position was nearly exactly as in the original-cool!
About the psu:I used a modushop case;the model is called "Galaxy Maggiorato",the type I used is "GX-187".Here some links:
http://www.modu.it/frontale_nero.jpg
http://www.modushop.biz/ecommerce/cat037_l2.php?n=1#3
the t-bone housing is much too small thinking about putting in a pcb,a potentiometer,a choke (i used the Triad) and a torroid and taking care of good ventilation (parts on the pcb get pretty hot!).
Apart from all of that I needed a certain amount of super-glue to fix the "flightcase" aluminium-profiles;now it´s fine.
The included shockmount is pretty good,but the cable is bull***t;mine was soldered very bad and had partly missing isolation/shrink tubes.
So I built new ones because the connectors where very cheap ones too.Now I have neutriks.
Conclusio:The t-bone set contains a lot of usefull things and is absolutely worth the money (it´s 149,-Euros here including shipping),getting a case plus shockmount is fantastic...therefore i started to build a second of those babies-putting in a "real" microphone is a lot of fun;the result is an awesome sounding mic.
Well,i think that was all for the moment,hope to have helped,
best regards from germany,
Udo.
P.S.:Here some pics again:
Edit:Case-type corrected to "GX-187".Pics added.
