david-p said:Thinking about it, it is not clear how many separate wires you have in your cable. I was assuming that you have 7, but if you only have 6 core cable, I advise using pin 7 instead of pin 3 for the reason I stated.
The cable I will use is this one:
http://www.thomann.de/se/sommer_cable_sc_octave_tube.htm
So there is 7 wires but 2 of them is thicker (twisted in picture). Good for ground?
david-p said:To advise on where the return goes I would need to know the model of transformer you are using.
This is the torodial I will be using:
http://www.tube-town.net/ttstore/product_info.php/info/p2192_Torodial-30VA.html
david-p said:The light you have chosen is likely to be much brighter than you want. I would have advised an LED with a resistor in series to reduce the brightness: 390 ohms would be a good start with a red LED. This can be increased in value to lessen the brightness.
David
This doesn't look to be too bright I think, but I guess I will find out and can switch to LED if that's the case.
http://angela.com/fenderredpilotlightjewelforguitaramps.aspx
Thank You!
/ John
