The Frizzle
Active member
I would like to use the capsule from the t-bone SCT 700 for the burn in. So I would just connect "front grid" to the front wire of the capsule and backplate to the side correct?
burglar said:Hi folks,
When purchasing 6028 tubes, if I can have them tested is there anything that will signify good performance?
Is it best to have them matched if possible?
Many thanks
B
burglar said:ok, great.
one other thing. without the dummy load switch engaged my voltage is over 300vdc. is this normal?
burglar said:Cleared cache, no joy![]()
Working fine on my PC with Chrome and on my Android.ioaudio said:Interesting, it works on my PC with firefox, but not chrome. Will look into it.
The Frizzle said:I checked every pin on the cable and it should be fine for testing.
My mic is still not really passing audio, only if I knock against the mic housing.
If I make noise next to the mic it's not passing it.
I did some measurements and I'm gettig
B+ 105V
Heater Tube one 18,2 V
Heater Tube two 1,42 V
26R 1,41V
Backplate 56 V
And then as far as I understood the output capacitor is the russian one correct?
I get 44,5 V on the russian capacitor.
