Emperor-TK
I thought I'd record the details of my MK7 build here, in case it might be of help to anyone else.
Final product:
"Stellar" Chinese body, $150 new off ebay. Same as many other mics, such as T-Bone SCT-700 and the Nady TCM-1050
Filled the engravings on the body with JB Weld and sanded flush
Painted with Rustoleum primer and Rustoleum gloss enamel spray paint (almond color reminds me of a Soundeluxe/Bock)
Mylar Thiersch M7 capsule
remachined the body's top plate out of acrylic to better isolate and lower the capsule
GE EF86 tube
fixed bias
Group buy shock mount
Power supply built in a BK Precision DC power supply case, modified and repainted (DC bench power supply ordered off ebay and was rendered useless by UPS, so I recycled the case)
mic power supply made with Moby's board
Used Gotham 7 pin cable from Redco
Triad inductor
Triad 12VAC power
200VAC transformer from stellar power supply
Next step is to roll some tubes and play around with output cap sizes. I haven't formed an opinion on the sound yet, positive or negative. Mt initial impression (with a random tube in it) is that it is woollier than I expected, but I'm not sure if it's a good woolly or a bad woolly yet. The random tube is dead quiet though. When Skylar's bodies are ready, I'll try a swap and see what changes with the new grill, etc. My capsule is sitting a little high still, even after re machining a new lower acrylic mounting plate.
What didn't work:
I could not get the stock Chinese power supply to work with fixed bias under any circumstances. I couldn't get the hum to an acceptable level, even after completely rebuilding the heater section with Max's retrofit design using the Vreg. I played around with every grounding scheme with no luck. Also, this mic had a 11.5VDC heater supply, and even with the extra voltage and using schotkey diodes, the hum was still there. Rebuilding the power supply with the inductor and a new 12V transformer fixed the problem. The mic is now dead quiet. Even after rebuilding the power supply, I had to play around with the ground connections a little to make the hum completely vanish. The scheme I wound up with is depicted below.
Final product:
GE EF86 tube
fixed bias
Triad inductor
Triad 12VAC power
What didn't work:
