[quote author="Gus"]No cap to ground at the 100K and 20K node in the plate/anode leg?
FWIW I have a circuit I like in one of my nady 1050 bodys and the linked microphone looks like a 1050.[/quote]
the 1µF cap is there, close to the voltage divider.
1050 looks similar to my housing - mine has the grille dome flat.
[quote author="RedNoise"]Would these fit in a G7 mic body???[/quote]
yes, if the g7 pcb fits in, the MK7 will for sure.
[quote author="jackies"]I look in my drawer, and it's not available... [/quote]
:wink:
i posted the checklist so people get the idea about what is needed. you propably need to buy a few tubes to find a silent one.
you will definately need a good capsule to beginn with. i highly recommend to use a very good quality m7 or k47 type.
regarding the tube type, i give clear recommodations for this project, but of course you can fit in anything and try everything - this is DIY after all. just dont expect it to sound as i intended if you use a different tube/capsule/transformer.
[quote author="lewilson"]Why not pin 2 and 7 to ground?[/quote]
it´s only 3,9 ohm from ground :wink:
