gbwilliams
New member
Hey all! I've purchased quite a few MN3005 chips over the years (both original Panasonic and XVive clones) for eventual use in a replica of the Rockman Stereo Echo. I've tested them all in an existing (socketed) Stereo Echo, and they all work, but for the most part, they don't provide nearly as long of a "tail" as the stock MN3005's from the unit. I suspect it's because the Stereo Echo has no trimmer pots inside to calibrate for different MN3005's, so the originals were probably hand-selected to work with the Stereo Echo's fixed component values.
To that end, I'd like to build a basic tester for the MN3005's. I'm considering using the schematic from the original MN3005 datasheet, but it only has a trimmer pot for minimizing distortion, which I believe is the input signal bias adjustment. Would I need to make any other aspect of this design adjustable to be able to properly test a random MN3005 chip? Perhaps there are other circuits that you'd recommend that already have such flexibility? I looked at various Memory Man schematics, but I want something simpler that only uses a single MN3005, so as to minimize external variables.
Any help is appreciated!
![1719009583619.png 1719009583619.png](https://cdn.imagearchive.com/groupdiy/data/attachments/83/83060-a9b4c32b1d69aabbabcc4914437373d8.jpg)
