Learner
[quote author="soundguy"]
how do henries in these examples relate to the sound that is coming out of the transformer?
dave[/quote]
The inductance will influence the reactance X L which is 2 x pi x F x L.
By substituting various value in F(frequency) eg. sweep oscillator, you can see that the reactance will vary due the frequency causing higher reactance at higher frequency.
Go here for more
AC turorial
dave[/quote]
if current is increasing in magnitude, the induced voltage will "push against" the electron flow; if current is decreasing, the polarity will reverse and "push with" the electron flow to oppose the decrease. This opposition to current change is called reactance, rather than resistance.
Impedance is a comprehensive expression of any and all forms of opposition to electron flow, including both resistance and reactance. It is present in all circuits, and in all components. When alternating current goes through an impedance, a voltage drop is produced that is somewhere between 0o and 90o out of phase with the current. Impedance is mathematically symbolized by the letter "Z" and is measured in the unit of ohms (Ω), in complex form.
Perfect resistors possess resistance, but not reactance. Perfect inductors and perfect capacitors possess reactance but no resistance. All components possess impedance, and because of this universal quality, it makes sense to translate all component values (resistance, inductance, capacitance) into common terms of impedance as the first step in analyzing an AC circuit.
Go here for more
AC turorial
