Youngwhisk
I am using some kk's as well. I have a very cheap crimper and am bending the small tabs around the insulation and the bare wire with needle nose pliers before I crimp and after if necessary. For this reason I am also soldering. I also make sure the little locking tab is bent up a little before I insert it into the housing. I insert the pin until I can see the locking tab fully in the little hole. If it is not fully inserted I use the needle nose pliers to grab the wire just behind the pin and carefully push until it locks. The only time I have had a problem is if the locking tab is not bent up enough. In that case I pull it out , bend up the tab and reinsert it. I have not had any be destroyed doing it this way. Have to be very careful to only use a little solder. I know soldering these is contentious. I do not anticipate doing a large amount of this so I can't justify the cost of a "real" crimper.
