b0b said:
Ok, I have one more question... If I was to rip out the transformer and make it a proper active DI do you have any good recomendations for schematics? I found this one
here
http://sound.westhost.com/project35.htm
Anyone know if this is any good? Seemes like a simple enough circuit and I should be able to modify the KT to this.
As John said, there's a number of things that don't work, but they can be easily corrected.
The input pot should be increased to 1 Meg.
R1 should be several Megs (10 Megs is easy enough to find).
C1 should be a non-electrolytic. 0.1uF plastic film is fine.
Increase R2 to 1 Meg.
Install small value (100p) cap across R1.
Put a little cap (10 to 47pF) across R5.
Increase C2 & C3 to 100uF 63volt.
Increase R6 & R7 to 680R, decrease R8 & R9 to 680R.
R12 & C8 are useless, just make a direct connection from Gnd to Pin 1.
Connect negative of battery to normalling contact of Input jack (sleeve break) in order to turn off battery when instrument is disconnected.
Insert diode (1N4001...7) between positive of battery and positive of C4.
You should end up with a pretty decent box.
