Just a heads up. I have a hum problem with a current project that uses a modushop case. This type has aluminium front and rear panels held together by side extrusions. Top and bottom covers are steel and held in place by pairs of nuts/bolts that run in a slot in the side extrusions
There is near perfect continuity between the front and rear panels via the side extrusions. However, there is over 40 ohms between the (bare metal of the) top and bottom panels and the front/rear panels. I am fairly certain this is due to the method of mechanical fixing of the top and bottom panels which does not make a good electrical connection. The result is the top and bottom panels do not act as screens. So I shall be making a direct connection.
ian
ian
