Here is the new board. The new pads for the custom edcor transformers which which will be 500:200(1.581:1 ratio) step down on the input and 200:1.8k(1:3 ratio) on the output. These transformers have huge bandwidths and I can't wait to try them. There is still the switchable output transformer which you could really use anything you wanted. Preferably dual winding audio line output transformer
. I like the Carnhill LO1166 or LO2567.
I also moved some of the terminal blocks around for easier wiring. Also made custom transistor pads for easier soldering and TO-5 pads for Q1 and Q10. I use these for TO-5 sockets to easily remove Q1 and Q10 for calibration purposes. All the orientations of the transistors have been revised and everything is pointing in the right direction ;D!
These boards use the Rev G power supply which has the DC adjust to make sure you are right at +30vdc. I have also incorporated input metering which is a great tool to see exactly what is coming into the unit. This is set at 0db but you could add a 3.6k resistor to make it +4db.
As of now there is no section for stereo connect, but the new boards will contain a section for this. I am working on a summing solution of late and hope to have this incorporated into the boards. I will post new pics when I have these done.
I will not be offering self etch files. What I will be offering is the board, custom Edcor input and output transformers and an Edcor power transformer. The power transformer is 24-0-24 but with a single primary. You will have to tell me if you need 120 or 240v. the plus side to this is you will always get .8 amps. I know when I did testing with lower amp toroidals, especially wired at 240v(amps cut in half), at extreme compression settings with input turned all the way up the lights would go dim in the meter and weird things would happen to the audio. But with higher current, I have not had this problem. Any who, you get the three transformers and the PCB for $150.00. This will include shipping anywhere in the world. You will also get a link to an easy buy BOM from mouser. This contains all of the PCB components, interconnects, IEC inlet, toggle switches and pots. It's about $75 for that order. Mike at hairball should be able to handle the attenuator, push buttons, meter and you could use his B11148 output transformer. And he will have cases and plates soon!!! Although you will need to drill two .25" holes in the front for the stereo link and transformer switch.
I am extremely happy with these compressor and I think there are a great reproduction of the F with some great new features. I would say this is a beginner to intermediate build. If you can solder and have basic schematic knowledge you could breeze through this in about 20-24 working hours. The more advance DIYer could probably get it done in 12-16 hours.
I just wanted to let everyone know what is going on and I should Have a proper pre order page up soon. Thanks again for everyone's patience.
Brandon
