Maybe because it's true? I will try to explain it.
First, imagine a clock pendulum or a children's swing.
The maximum velocity of the pendulum is at point B, at points A and C it is zero. So the highest voltage that the ribbon gives is in position B (and it is in motion).
With a condenser microphone, the voltage is highest when the membrane is closest to the back plate (position A for example), and lowest when it is furthest away (parameter d, position C for example). It should be clear from this that the voltage from the condenser microphone and the ribbon microphone cannot be in phase and in some conditions they are shifted by 90 degrees.
Below are the formulas for both microphones from Beranek's book on acoustics.
Ribbon:
Condenser:
I hope that there is no one here to relativize what is written in that book, just as what is written in Ballou's book and what those "ignorants" from DPA have concluded are relativized. I have nothing more to add here.
I have nothing to object to that model.
