Really?Until current flows and then falls in the transformer primary for the 1st 1/2 cycle you can’t get an output voltage on the secondary
You are negating evidence. Anyone with a an oscilloscope can see you are utterly wrong.- if you looked at an impulse test there should be a significant time lag of around 180deg - in that case this signal at the transformer output of a dynamic or ribbon will lag timewise behind the signal from a condenser capsule by 90deg and no longer lead by 90deg, unless the condenser uses a transformer as well in which case the condenser mic output should lag by 90deg timewise. Lots of transformerless condenser mics out there.
Try comparing a looped impulse audio signal like a snare hit on the input and the output of an audio transformer - the output voltage should lag behind the input voltage timewise if observed on a scope.
There can’t be an output voltage without the magnetic induction occurring to energise the secondary winding, which relies on current flowing and collapsing then reversing in the primary winding then this induction can produce a voltage at the output - this takes time to occur. It’s misleading to say voltage “leads” the current at the output of a transformer - phase wise yes (looking at a sine wave on a scope would make you see that as all wavefronts look identical anyway), timewise no, the output voltage doesn’t travel back in time to be leading the current that created it where the current hasn’t even started to flow for the leading wavefront.
Unless I’m completely mistaken in all of this???
You think that the output voltage can appear only after a complete half-cycle has been completed. Think of the consequences: the output signal would suffer a variable delay, of 25ms at 20Hz, 0.5ms at 1kHz and 25us at 20kHz. Transformation is instant, no time-travel there.
As I mentioned several times before, this is a very different issue. "Phase" effects due to different acoustic paths are well known and have nothing in common with transformers.When putting dual mics at one location to get the sonic benefits of each I do a simple slap test recording to see if there’s a phase/time lag in one and then placement adjustment can be calculated by using the time difference between the two waves mSec/1000 x 1100ft. Recording engineers have been doing this for years - takes minutes to do.
