Does anyone have a trick for using a multi turn trimmer as a panel mount pot? Multi turn pots are pretty expensive. This is for occasional calibration use.
I’ve thought about gluing a tube to the screw adjuster. Then glue a pair of shoulder washers to the tube to keep it in the hole in the chassis.
