i have one of these on my bench because has a noise problem
the flanging effect and all the controls work but there is a loud motorboating noise too
no niose in bypass or when the mix knob is in dry position
i tried to probe the circuit and i found the noise is on the +12V rail and almost everywhere in the circuit
on U10 pin 1 there is noise when the regen pot up is turned up. with regen at minimum there is no noise in that point of the circuit
i am trying to narrow the area where the noise builds up but this is a complex circuit for my skills and at the moment i can't figure out a solution
i have recapped the unit but didn't solve the issue, now I am suspecting a bad IC.
the BBDs are the only socketed and i have tried pulling them out with no results. at least these seem ok, it would be impossible to find replacements
i would really appreciate if anyone can help me understanding the possible areas where the noise starts and which components trying to replace
schematics are in the attachments
thanks !
thanks !
