damien
Hello,
Just wanted to share my design files for the SSL quad comp clone.
The two files are made with "frontpannel designer" for schaeffer milling process.
the holes for the 'power' & 'bypass' buttons are made for the unbreakable Nikkai UB2 switches (15*15mm holes)
and the bargraph hole is made for RS component ref:259-561 (100uA) galvanometer.
RS component 259-561
download the schaeffer software at:
http://www.schaeffer-ag.de/index.php?option=com_content&task=blogsection&id=8&Itemid=73&lang=en
download the file, grey or black, following your taste:
http://www.yourfilehost.com/media.php?cat=other&file=damian_gyraf_ssl_8_grey.fpd
http://www.yourfilehost.com/media.php?cat=other&file=damian_gyraf_ssl_8_black.fpd
check the position of the holes on the left and right of the pannel to fit with your rack holes.
This is just a sample!
You can adjust everything, from the holes position and size to the brand on the left side...
I suggest not to keep the SSL thing and prefere using your own label so that you can show off to your friends ;-)
I have not yet make mine. I will buy the UB2 switches and see if it will sit correctly in this dedicated position. And I'm currently working on my own brand label to engrave on the left.
Hope it will help you!
Damian
Damian
