JasonWWW
Active member
That front panel design is GREAT!
I also don't know what are those trim pots on both filters for?
Does adding the HP filters change the ratio or threshold behavior?
You mean VR2 & VR3 in this schematic ?
http://home.hetnet.nl/~chickennerdpig/FILES/API/API-Thrust-HPF-circuit_20060310.pdf
Please do read those notes in that schematic, all info was there already.
Note *1*.
The main thing to remember is this: You need to be sure that your VCA is seeing no more than 120mV or your ratio will be way off. (I.e. you are seeing 260mV at the Ec pin)
