My Transformers
analag
Mars
Ok, here are the transformers I've been winding for my next project.
(4) line outs and a power.
analag
[quote author="gyraf"]Looks good!!
Nice idea, that way of mounting them onto chassis..
Jakob E.[/quote]
Thank you...the small ones are interleaved (16) times, the larger ones (8) times and with tertiary winding.
I'm very happy with the sound of these thingys.
analag
the small ones are interleaves (16) times, the larger one (8) times and with tertiary winding.
Damn, that has to have taken some time..!! :shock:
..or did you accidentally find a cheap source of chineese slave labor?
Jakob E.
Did you tighten the long bolts in the mounting brackets using an inductance meter? M4 C cores nice
[quote author="AnalogPackrat"]Nice job, analag. What sort of winding setup do you use?
A P[/quote]
Manual winder....real simple but effective. Found all the parts at the local hardware store.
analag
[quote author="Gus"]Did you tighten the long bolts in the mounting brackets using an inductance meter? M4 C cores nice[/quote]
I used an inductance meter for connecting the interleaves and matching the inductance between each pair of transformer.
analag
[quote author="Kid Squid"]
would it be possible to see some closer pics ?, interested in the Transformer bodies[/quote]
Do you mean the brackets that I use to bolt them up? I'll post it after I get some rest....been drilling aluminium all day. I'm DIYing the rack enclosure as well. Going for a vintage appearance on this one.
analag
Looking very good! :thumb:
[quote author="analag"]I used an inductance meter for connecting the interleaves and matching the inductance between each pair of transformer.[/quote]
Is the meter accurate enough for that? Many L/C meters seem to have an accuracy of few %'s at best.
Well, apparently these things work, so.. :cool:
REALLY looking forward to seeing the finished beast , brawd.
OH YEAH :thumb:
Steve :thumb:
(30) tubes (12) transformers. (1) tube and (2) transformers go on the inside
This is a (10) rack space unit...only 5 inches deep.
analag
