KraftWerk
- Joined
- Aug 14, 2010
- Messages
- 103
I decided to make a copy of the T1454 but I have some doubts. I believe the housing of the original T1454 is from mumetal. Also, there is a brass sleeve inside which is not easy to replicate so I Decided on the housing that Carnhill has.Does anyone know if this Carnhil case is also made of mumetal or is there some kind of lining inside? I made my own bobbin that has a layered shield..would it be enough for the first outer layer to be a copper layer and then a 0.1 layer of a mumetal like foil and for the housing to be made of 1 mm carbon steel?.please look the picture.
