Sorry, no spies around ;D
PRR said:>> Jfets were widely used in the fetrons, solid-state tube replacements
> jFETs but could not find any rated above 40V
Early JFETs were available tuned for large gate breakdown. Rheinfelder advocated 300V JFET designs in 1966.
gm seems to be an order of magnitude greater than in small signal tubes so trading some for higher voltage operation should not be a problem.Gate breakdown conflicts with transconductance. Most users wanted Gm, not high voltage. I have not see a hi-V JFET in decades.
JFETS have merit in LTP (long tailed pairs) precisely because of their lower transconductance than bipolar devices, that changes the compensation trapeze act (maybe somebody needs to make a JFET version of a DOA)..... oops did I say that out loud?. Perhaps explaining the huge popularity of bifet op amps.ruffrecords said:I did not realise that.gm seems to be an order of magnitude greater than in small signal tubes so trading some for higher voltage operation should not be a problem.
I spent my entire career in electronics product development without ever using a FET as an amplifier. Used loads of BJts but not one FET except as a voltage dependent resistor in a compressor It is like going back to school again.
ian
ruairioflaherty said:I beta tested the Force, the designer is a friend. I can confirm that the circuit works well and has lower distortion than the all tube version of the same pre in the Core. Both have their place, I will reach for tube gear because of its distortion signature.
