The led next to mute button is for mute. the led right below the eq is the over light. you should record with the channels before you recap them. I always liked the way they sound all original. I've racked a bunch of those aswell. Take the pan pot out and put a 10k pot to use as a fader. you will need to jump the insert point aswell. use the top buss switch for phantom power. hope this helps
