Neumann M49 Clone : Build Thread Puck Style (TLM49 Conversion To M49 b-c)
sorted the issue on one, was my fault wiring in the transformer!!, the M49c one still buzzes a little so will look at next week!!!
regards
Spence.
Did you ever find a solution? I have the same issue, and can’t seem to figure it out. I’m also building a 49c?
Hey guys, I just finished my build and I’ve got a ground buzz coming through. The microphone works, sounds great and doesn’t have any other noise, just a ground buzz. All of the grounding seems to check out and I have continuity throughout everything. I’ve searched through this thread to see if anyone has had a similar issue, but couldn’t find any posts. Does anyone have any ideas on what I should check? I also ran it through an isolation box to see if that would get rid of the buzz, but it did not. I’m kind of stumped. Also, once I kill the power to the PSU, and the capacitors are still charged, The buzz goes away in the mic sounds fantastic.
Put it in the body and try again.
Strange part about the noise is I have continuity everywhere I check. I can put a probe on the ground pin of the IEC and probe all way through the PSU up the mic and it all checks out.
Not sure what the noise is that you are referring to. What I heard in the video, was a capsule without any screening. It definitely shouldn't sound like that in its mic body.
Headbasket, body tube, and bottom bell all have continuity?
Yes, I completely assembled the mic and checked continuity on all those places you mentioned, and there’s still a noise. That’s why I’m so perplexed. I actually bought enough to make a pair of these mics, so I assembled the other one, with PSU and I have the same noise. So I’m obviously doing something incorrectly in the build process. I just haven’t figured out what I’m doing incorrectly. By the way, thanks for taking some time to help with this.
This may be, but all I could hear in the video is interference. If you have it assembled, and record a video, it should sound different. It may be that you have a ground loop in the power supply. You might be hearing the ground loop with and without the headbasket & body, but I couldn't tell from the video without the headbasket.
My grounding philosophy is to terminate the shield to the mic body as close to the connector as possible with as short of a wire as possible. I usually attach with small ring terminal where the rails connect to the bottom bell. I always connect 0V to the mic body, sometimes at the same spot where the shield terminates. Inside the power supply, the shield again terminates to the chassis as close to the connector as possible. I scrape paint around the connector mount hole and terminate there. I only have one connection from PCB 0V to the chassis inside the power supply, usually at the same point as the shield.
Ok, I finally tracked down the noise to the heater section of the the PSU. If I take an external DC power supply and bypass the heater section, tie it into the xlr line, the mic is crystal clear. The noise looks like ac noise, almost as if the capacitors aren’t doing what they’re supposed to. The diodes are orientated correctly and the transformer is correct as well. Any thoughts? IMG_9490.jpeg
Just for any future builders, I was able to figure out the issue. I would however, like any feedback onto what I’ve done to fix it. Long story short, after probing around it appeared as if the heater side of the PSU wasn’t grounded. So I made a little jump From a spot of circuit board to 0V and that solved everything. Again, I would love any feedback on this and how I was able to fix it.
    1.7 MB
how did you determine where to jump from 0v? im having the same 120hz problem in a danny u67 just not sure where to jump it to 0v on psu pcb
Is this the sound of my 6S6B-V on the fritz?
that's 2.4ghz wifi. You can try messing with grounding and that might help to some degree, but these old mic circuits are not designed to reject modern RF emissions. if you have a dual band router and a small enough house (and router software that supports this) disable the 2.4ghz radio in your router settings and leave only 5ghz enabled. if you are in an apartment, you will just have to deal with it.
Ugh thank you so much. I have a session tomorrow but all I did was move the router a bit and it's clear.
For some reason, on an eero, I can't turn off 2.4ghz...
Anybody have any alternative ideas for the teflon insulated pins? Expensive when building a pair of mics.
Mounting your components in the air, especially the hi z section, above whatever thing your are using for the rest of your components
The capsule output / grid net especially
yeah, that would be the best,
It's just that there are several points in the air, close to each other, with multiple components wired to each point. One of the styrene caps has isolated turret pins on both sides of the cap which would create a string of thee components in series in the air. Maybe I just need to toss the styrenes for more stiff legged caps. Hah. I can see why something to solder them to is convenient.
I'm referring to Dany's pcb btw
Maybe I could heatshrink the bottom part of a resistor leg and then glue it into the hole. Not that elegant.
