Neumann OEV: Calculating resistor values for reducing increments?
adamasnan
Hello! I hope someone can help me calculate/specify resistors to replace those in the Neumann OEV EQ for half gain increments? Or better yet 1/2/3/4/5db or thereabouts?
for example, in the schematic (attached) I see that the first band (S3) has the resistor values listed, and a sum of all resistors either side of the 0 gain point are 60.2k (including R3).
I am going nuts trying to figure out the values, the theory of simply halving the values and then doubling R3 doesn't work out as I naively hoped..!
I would be satisfied with only changing the values of the high shelf and mid band gains, and leave the low shelf as is.
Help please!
Thanks!!!!!!!!!
  • OEV.pdf
    182.6 KB
..replace with a pot, set to wanted steps, measure pot positions..?
exact total value probably not all that important, if you don't need the maximum available range anyways..
/Jakob E.
