kante1603
;D ;D ;D
Krumlee said:Yes, use the Kemets - they'll sound fine.
If you've installed the 60M resistors then stick with them - they'll also be fine. I think the 68M ones were only specified because the 60M ones were unavailable or expensive - see way back in the thread. There's no difference in sound quality.
Enjoy your build...
dreadheaded said:I have finally got a chance to do some serious testing with my pair, and I have noticed that one looses a LOT more signal on omni then the other one
I was just wondering how much signal we are realistically expecting to loose when operating in omni
dreadheaded said:I have the green board and it has the beezkneez k8, the other mic does have a peluso capsule in it I have thought that could be causing some of the difference.
dreadheaded said:when I switch to omni the readings I get from R4,R5 and either side of the capsule seem odd, on cardiod and figure of 8 all 4 are showing 38v or there abouts, when I switch to omni, it drops to 6v
dreadheaded said:interesting, it seems the backplanes are not isolated from each other!
dreadheaded said:Thanks very much Dany!! not only for the project but the great support too!!
As a side point, this sort of issue shouldn't affect its preformance in cardiod should it? I presume it means that only omni doesnt work completely, and I guess it explains why figure of 8 sounds so different on both sides of the capsule!
only its significantly darker than the one with the peluso capsule
fazeka said:Hi All,
I'm getting very close to finishing my mic. However, I have what I suspect is a wiring issue with the capsule and having some difficulty understanding how to troubleshoot...
I first wired up the capsule and got very low output on figure-8. Omni and cardoid were adequate output. FWIW, I am using tskguy's (Eric's) capsule.
So then I disconnected the backplate wires from the PCB as I figured I got them crossed.
Soldered one of the backplate wires back to the other BK terminal on the PCB and then tried the mic. OK, I get omni with adequate output. Cardoid and figure-8 are identical sounding, also with adequate output (slightly more than omni, FWIW). Figured I'm on the right track, I solder the other backplate wire to the remaining BK terminal. At this point, the backplates are wired opposite to what they were initially. However, the mic sounds exactly the same as it did initially with very low output on figure-8.
Can't think of what else to try next. Any guidance appreciated.
Chris
