wave existence
trapped in the zohar
anyone got mouser links for the toggles used for the switch pcb? guessing they are SPDT on on and on off on, cant seem to wade through all the switches to find the correct orientation, thanks.
Hiya, I'm in the process of building a pair of U87s and wondered how you rate the AA capsules (if you used them)? The bodies I have are quite small, so I think I am going to go for cardioid only (no switches/single back plate). Also considering the microphone parts K87 as I'm trying to keep costs down. Many thanks.Oops, my fault you asked very clearly.
I'm using two K67 type capsules matched by Dave Thomas at AAMicrophones. They are essentially the same as those sold by Microphone Parts, but they are re-skinned with 6 micron Mylar. They should have slightly less high frequency lift in the 7-9kHz range as a typical K67 type capsule. Since I already have two "dark" versions using K47 type capsules, I'm hoping this pair has slightly more "air".
More sonic crayons to add to the box!
See 3u audio for a good cheap K87 capsule.Hiya, I'm in the process of building a pair of U87s and wondered how you rate the AA capsules (if you used them)? The bodies I have are quite small, so I think I am going to go for cardioid only (no switches/single back plate). Also considering the microphone parts K87 as I'm trying to keep costs down. Many thanks.
Have you checked that the transformer is wired correctly? Very weak signal is a symptom of wiring the transformer backwards.ok so i had the front/back diaphragms mixed up. now i get sound but its very faint, have to crank my pre up all the way to hear anything. also when i switch to between different patterns there is a kind of loud stuttering, any ideas?
it appears to be: p+ and p- are wired to primary + and -, same for s+ and s- -> secondary + and - from data sheetHave you checked that the transformer is wired correctly? Very weak signal is a symptom of wiring the transformer backwards.
It should be fine. If the pins don't line up exactly you can bend them a bit.I cannot find anywhere Bourns PV37X253C01B00 trimmer, so my question is may I use Vishay T93YA253KT20 as a replacement?
P.S. Please know that mouser isn't an option because of the very high costs of the transport.
