Spencerleehorton
Hi Guys,
I'm in the process of making some original Neve BA283, BA284, B205, B211, BA182 pcbs to put together several pre amps and wondered if i could use a combination of a Lorlin 12 way switch pot for frequency selection and a 10K/47k pot for the gain rather than the expensive dual concentric pots?
I already have some 3 gang Russian made pots for making up the gain control and these work fine when using a mesh screen over the connections but only have 11 clicks on them, so i'll loose a position a the top.
I only want to have these for Mic so i can save a little on loosing the line txf.
I have also had some really good results using some Sowter txf as input txf but will be getting the carnhill for output txf.
Im also trying to keep 2 units into 1U as these will be replacing my 6 x SSL 9K unit as i don't use it.
below is a low res of where i'm at with the pcbs.
regards
Spence.
regards
Spence.
