snipsnip said:Im doing it without a resistor. Works fine.
stitch-o said:snipsnip said:Im doing it without a resistor. Works fine.
Those board grounding and xfmr check tips might have fixed my issues: fired up for an hour and a half and no crackle so far.
I have a session this afternoon so we'll see if these pres make the distance without breakup.
You ever get your preamps biased? I will crank the gain on the EZ1290s to full, then turn sine tone up from zero til it clips on the scope.
I need to adjust the parameters on the scope as well.
mitsos said:If your regulators ran too hot, they'd probably shut down.
Now that I think about it, I had a problem with a bad cable... Can't remember what it was..it's bee a while. But it didn't work right! ;Dsnipsnip said:the input or output on the tranny.
My suspicion is that the crackle is the cable joint moving under tension.
