haima
adrian said:OK, so i tried as you said,
once again you're right but the resistor doesn't changes anything...
in fact the transformer noise appear at the 2 last gain step and disappear if i turn my output trimmer down..
well, you've got oscillation in the input amp stage of the preamp. this is probably caused by a little bit of the LOUD output leaking into the quiet input stage, creating "positive feedback". try moving the input transformer away from the output transformer... try moving the fader pot around, try moving anything around, while listening - see if anything changes.
check the all those shielded cables are terminated (at only one end) to 0v - perhaps something isn't shielded?
have you tried using the preamp with a mic yet? try it on the lower gain settings - does it sound ok?
btw: your components are sitting a little bit sloppy on the board - you should pull the leads down through the board and angle the legs apart before soldering to keep the component flush to the PCB. keeping things neat will give you more reliable builds, and in some extreme cases you could possibly get oscillation from components sitting too close if they are all sitting high on the board like some of them are...
hopefully your preamp will be working 100% soon - i think you're almost there!
