- Joined
- Dec 10, 2016
- Messages
- 119
After unsuccessfully trying to find a clone of the T1310 I looked around for a currently manufactured replacement. I found the Triad C-24X seems to be close enough for 'rock-n-roll' if you will. The T1310 is roughly 1H, 12 Ohm, 100mA capable gapped inductor, the Triad C-24 is 1H, 40 Ohm, 240mA capable. There are other options available from Hammond (158SA and 158T) but they are more expensive.
I tested the C-24X against the T1310 in a basic 1272/1271 circuit using the output of Pin 'F' and didn't measure any difference between either of the chokes and a Carnhill 1148.
Unless there's something I'm missing I think I'll just use the C-24X.
Just letting you know.
https://www.mouser.com/ProductDetail/Triad-Magnetics/C-24X?qs=xrpI9KL/Xvsp8oLEd8wC/Q==
https://www.mouser.com/ProductDetail/Hammond-Manufacturing/158SA?qs=rToDpkxn9yWZ13AxG7qCgw==
https://www.mouser.com/ProductDetail/Hammond-Manufacturing/158T?qs=HY6QdUiTBExb6jHnekQwHw==
