Bus resistor values vary and for more channels, the value is lower.
If I was doing 8 channels of balanced I'd probably go somewhere between 4K7 and 10K.
Probably more towards 10K.
Bus terminating or shunt resistance then is calculated according to how much gain you decide to run.
So that depends on the turns ratio of your input transformer (if you have one) and/or the gain available in your makeup amp.
For a balanced bus into a neve style make up amp (unbalanced) you need a transformer.
Basically you 'knock down' the bus levels as far as you have make up available.
ie. the impedance of the bus, which is the parallel of the unterminated bus and the termination resistance should be low, for various reasons, not least of which is that is what makes switching channels in/out not jump up and down in level too much.
Anyway, there's a lot of opinion, some calculations etc as to what is the way to go.
8 channels balanced into a 1:2 transformer (neve stuff apparently used 1:2) with 35dB gain might be 300R or so.
Best to calculate it. I'm feeling a little lazy right now, so I'll leave that to you.
I'll post more if you remain stuck.
