ruckus328
tv said:Disclaimer: that's what 2180 appnotes say - use a single 5K1 to V-. Try to ask for the "second opinion" from people who have devices configured this way or the "old way".
Also, regarding rail voltage, appnotes say that the VCAs are current-in/current-out devices and in this regard less dependant on actual rail voltage compared to voltage-out devices.
The sidechain VCA should not be as critical regarding distortion, so the "dist-trim" could be left as-is or possibly even completelly left out.
Interesting - so basically whether I feed it 12V or 15V, resistor values should remain the same. Which causes me to start to question those values, since as you said - app notes don't say anything about them, but I would think if they were unessecarry or caused some sort of issue, somebody would have brought that up by now. I believe Gyraf & Turbo boards both instruct to put a 3K9 resistor between pin5 and ground, not a 5K1, and Marten's page only says to change it for the audio VCA's. Come to think of it, I seem to remember somebody actually saying to leave a 3K1 there for the sidechain VCA on one of the threads when I was building my first unit.
I do see though that Marten says the 10K between pin 3 & 5 can be removed on both the audio and sidechain VCA's (missed that).
Sidenote:
Kingston - aware if this issue - my schematic has the 100pF intact.
