Name that transformer: :grin:
http://vacuumbrain.com/The_Lab/TA/Telefunken/winston_iron.jpg
Re-wiring a V72 choke for a friend.
I was blown away by the lams used. Took me an hour to figure out how to take that choke apart. The lam is one piece! You have to bend it carefully in order to lace up the coil. There is an air gap of about 0.020 between the center leg and the E lam. I guess the reason for doing it this was to make certain that the gap never changed with time. Pretty clever. Realize that the gap does not go all the way across the lam in this situation. Only the center bar.
No, I do not think you can buy this lam anymore. Supposedly M6. Weird blue tint. Probably something to do with the insulation coating process. Ollie don't wanna say nuthin about it.
Once the coil is laced up, there is tension between the lams and bobbin due to the slight bend that you have to put on each lam to get it thru the bobbin tunnel. The tension from each lam adds up to a pretty hefty force, so if you take apart your V72, be careful with that choke! If the lams slide up 1/8 inch on the bobbin, POP! They will spring out a bit and you will have to fight to get them re-oriented. As I said many a time, so far each transformer I have taken apart has had at least one thing different than the others. This choke has many things different!
http://vacuumbrain.com/The_Lab/TA/Telefunken/v72choke_lam.jpg
