thanks babyhead ,
im redesigning the ver 1 over the next 5 weeks ,
there's a lot of corrections like that i need to do ,
simple things like make the radial caps spaced properly.
etc.
plus sprucing up the design with my new skills aquired from designing the
ver 2 'opto' la2a pcb.
it is true that the heaters are already connected on ver 2.o
along with the fuse , and transformers (works with leaded x formers
also)
i just built one with utc ha100x and a-24
really sounds great.!
heres the pcb , notice how the heaters are on the top side of the
board , i used a much thicker board in manufacturing to insulate between
the heaters and the signal side , (that prettymuch doubled manufacturing
costs in it's self) then add the 3oz copper surface ,
2 amps needs some pretty thick copper , or the trace sizes were
going to be pretty thick.
it was pretty tricky getting the heaters to fit into the design ,
after a million designs i finally came up with the 'stadium' (tm)
concept
where the heaters go 'around' the signal circuit instead of 'through'
the circuit.
and then was able to position all the signal traces to avoid intersecting
with the heater traces.
the worlds greatest puzzle.
glad im OCD ,
lol.
