nielsk
I had a request to build a monitor controller, and looked around at the possibilities. What I found was either very expensive, awkward, lacking features, or lacking quality. I wanted a rackmount unit for the audio portion, and a small desk unit for controls and talkback, with one cable in between. So I began to explore the various ways of doing this, and built a prototype of a VCA based volume control w/ relay switching for source / destination selection. The VCA circuit works excellently, sounds transparent, tracks perfectly, and has extremely low distortion. The ability to use a low cost single gang pot makes it cheap & easy to obtain continuously variable, very smooth level control.
I realize there are some with prejudice against VCAs, but I suspect that their opinions are not based on actual experience with extremely high quality low distortion modern components.
I am sending the prototype around to some engineers for testing, and thought I’d toss this out to the forum to see if there is any interest in this as a project, and get some input on features. If there is interest I would consider offering it as a board set or possibly a kit.
Here is the main feature set:
Relay selected balanced stereo source select.
Balanced stereo inputs, feeding a VU meter buffer / driver, the headphone / cue section, and the VCA speaker level control.
Relay selected balanced speaker feeds.
One stereo headphone amp will be fed with the selected source; another will be fed with the selected source & the talkback mic signal. This CUE signal will also feed a balanced line level output.
A dedicated mic pre chip (THAT 1512?) talkback preamp in the desk unit with gain control and press to talk switch, wired to an XLR for user mic.
Some initial areas for feedback:
Should I use the tried and true 5534 based balanced input and output stage (what is in the prototype), or a dedicated line receiver and transmitter? The dedicated does cost more, but could offer higher performance, and a lower parts count.
The meter will follow the selected source, what about a peak circuit?
What about using something like the RNK80 DtoA board for a digital source input?
A –10 unbalanced input option?
With the idea of making aspects modular so one can build to suit, I contacted the EXPAT guys to see if they could program their switch board to interlocking, and they have obliged. Their current version supports 3 lighted switches, this would accommodate 3 input sources and 3 speaker selects. They are working on a 4 switch version. Use of their modular relay board could allow as many or as few of each as desired. They are going to send some samples to me for testing
