G
Guest
Guest
For those following my little modular long term mixer project I have a question.
Most of the DIY projects assume that you are installing the xlr, jack plugs and connectors from PSUs in the chassis.
However - I don't want to go down this route - but go down a pin out route (like the Telefunkens)
I plan to put the audio and power connections into the pins and use different coloured cable connectors to indicate the different voltages available
I can't imagine that the cable runs will be more than 12 inches/30cms or so
Question 1
Is it okay to run power and audio together in a ribbon cable or should I think about separate cables grouped within a cable run?
Question 2
A really simple question...
I wish to put a cable connector at a right angle to my eurocard plug board - are we talking a DIN 41612 type C connector?
Question 1
Question 2
