Nickel Plating Headgrille
kingkorg
GDIY Supporter
Norway
This stock gold color was driving me crazy, so I decided to try this out.
I used this video as a tutorial, and it worked out better than I expected.
It gave me even vintage, gun metal look that I wasn't expecting. I haven't even prepared the grille in any way besides cleaning it with alcohol. I had to rotate the grille a lot during the process to get even finish, and stir manually to get rid of bubbles. I did get some "dendrites" on the grille, but they were easy to remove, and under those the finish was as on the images. No polishing, or anything like that. I used 12v throughout the process.Screenshot_20230912_185548.jpg 20230912_185402.jpg 20230912_185225.jpg
RuudNL
Haule / The Netherlands
So you plated nickel over the 'gold' of the headbasket?
I have no experience in plating, but I can imagine that nickel won't hold on any metal.
But I like the idea(!), because I also have some microphones with a 'gold' headbasket.
It is too much 'bling-bling' for me, maybe rappers will like it... :)
kingkorg
GDIY Supporter
Norway
Yup. There seems to be much chemistry involved, but it worked out great for me. Guess I was lucky. The bling factor was bothering me as well.20230914_132224.jpg
rock soderstrom
Tour de France
Berlin
If my memory serves me right, copper is normally used as an intermediate layer for nickel plating on certain surfaces. Gold can also play this role, but it is not usually used for well-known reasons. It is much more expensive than copper.
Icantthinkofaname
Ontario
It gave me even vintage, gun metal look that I wasn't expecting. I haven't even prepared the grille in any way besides cleaning it with alcohol. I had to rotate the grille a lot during the process to get even finish, and stir manually to get rid of bubbles. I did get some "dendrites" on the grille, but they were easy to remove, and under those the finish was as on the images. No polishing, or anything like that. I used 12v throughout the process.View attachment 114435 View attachment 114437 View attachment 114436
Thank God MXL changed that colour scheme with the V67HE.
RuudNL
Much better! I have a couple of Chinese microphones with an (IMHO) ugly 'golden' headbasket.
I hope I can find the courage to do the nickel plating myself.
It seems it is not overly complicated and from what I read you don't need an ultrasonic cleaner and stuff like that.
The only risk can be that it fails... (The video explains everything in detail, but in my opinion you usually get the best results if you don't exactly 'follow the book'! :) It is the same with gardening... )
kingkorg
GDIY Supporter
Norway
Also worth to mention, as the mesh needs more tumbling and turning, getting rid of the bubbles... I stopped and repeated the process several times and got this result. So if it fails in the first go, you can just repeat.
I'll certainly try this for the whole body eventually.
RoadrunnerOZ
GDIY Supporter
Australia
I’ve done similar plating for worn soldering iron tips which I’ve re-profiled, cleaned and polished and then plated. I was able to create very fine chisel tips for soldering SMD components like multi pin IC’s. I used ammonium nickel sulphate and nickel strips and electroplating tubing to wrap the strips in.
kingkorg
GDIY Supporter
Norway
Now that is an awesome idea!
MicMaven
USA
Whoa - Nicely done. I posted a "like" but I want to emphasize how much I like the result. Understated elegance, looks expensive. My wife agrees. (And this marks the first time in x years we have agreed on something . . .) . James . :)
RoadrunnerOZ
GDIY Supporter
Australia
Hmm - maybe a Euro-only product; never seen in US stores.
Rust-Oleum do a satin ivory silk available at most hardware stores here - it’s a Zinsser brand paint - indoor/outdoor self priming, all surfaces.
You can also use automotive paint which will require primer and clear-coat as a top coat but, then you can choose your finish anywhere from gloss to ultra-flat in the clear. The color is just a base coat, the clear-coat provides the protective layer - same as with vehicles, the base coat is prone to finger marks etc so if using do not handle base coat surface until clear has been applied. I have used spray can auto lacquers for all sorts of projects (including vehicle touch-up repairs). Available in any auto supply stores, they even mix colors to code if there’s a vehicle color you want to match. Fiat and Nissan both have a color similar to the above in solid non-metallic finishes.
RoadrunnerOZ
GDIY Supporter
Australia
