solder_city
hey- i want to make a simple passive mix to combine 8 to 12 line level sources, with level controls and maybe even pan pots. i need high (5k - 10k) input impedance and low (159 -600) output impedance. to minimize loss i figure i will need matching transformers on either inputs or outputs- stepdown input transformer and low impedance mix circuit, or high impedance mix circuit and stepdown output transformer. i m not sure of the best way to go. heres my thinking:
low z network means less resistor noise and less chance of noise pickup, but signal level will be lower due to stepdown input- so possibly no difference in s/n? also, more transformers needed (one for every input)
higher signal level with hi z network, but also higher resistor noise and possibility of noise pickup. also could be loss of bass response from high source z driving output matching transformer and or distortion from low signal level depending on core material. a very good trabsformer would have to be used here, advantage being only one needed per output. (inputs dont need transformers unless it has to be balanced).
your thoughts?
thanks
your thoughts?
thanks
