Noob needs help with z5600a II mic repair
What value is C3? 420v something is all I can read inside the mic, on the schematics it impossible for me…
Given the uber-low resolution of that schematic, we can be quite certain it's supposed to be 9.1k; you probably can't even find 8.1k resistors anywhere; closest standard value is 8.16k (E192 series); 8.2k is an E6 value though.
The "debate" about this is purely academic though - as i mentioned, the exact value is NOT essential at all, in that position / role in the circuit.
Great, thanks
Could be 18pF, possibly? A much more standard value would be 22pF though - you might not mind if the attenuation ends up being a bit more than 10dB with the pad activated.
Thanks again, and no I wouldn’t mind that really
Reading up on the E-series it seems likely that the mic uses e24/e48 series, and I think that both 8.1k resistor and 18pF are values that fit within that series no? If I can get those that is, otherwise I understand the 9.1k and the 22pF are more common and can be used without problems.
Either one should work.
And stuff like chatgpt is only as good as the stuff it's fed; it's unable to discriminate between good information and bad/inaccurate information.
That cap C3 definitely looks like 18pF - readily available in 500V.
On your mic it looks like R3 is the wrong value - doesn’t look like 51M, also R6 R9 R10 look like they’re all 270K - image 031638?? R8 is different in two different photos of yours - one shows only two bands as the rest are obscured - green,brown - 5,1 - assuming 51M here - image 033858. Then the next shot with the whole resistor visible shows what appear to be orange,orange,black,green 33M image 032218 and several others. Did you change that resistor? What value is it now?
I have yet to change any resistors, as my local electronics store was out of most for some reason yesterday. I could buy two 150k@2watt, which I did, and I soldered them together in a V/triangle shape, and they measure right, but they can barely fit haha, haven't soldered them on yet.
And yes, they are all 270k those three in mine, which is wrong. And one measures completely wrong too, 1.1kohm.
Just saying - 2 watt is way overrated. Even half a watt would've been more than plentiful - you'd expect maybe 1-2mA to flow through those (at idle), which works out to about 27mW. Or hell, even the full 180V that supplies the tubes, across 300k (if, say, somehow, both halves of the tube shorted out), would burn up a measly 108mW.
Here are few closeups of mine Z5600. Every is ‘still’ stock design.
Hope it helps .
    2.2 MB
    2.2 MB
    2.5 MB
sE Electronics, z5600a II Resistors and Capacitors
MIC Resistors:
R1 = 1Giga-Ohm - small flat - wattage? width max 1cm
R2 = 200M - small flat - wattage? width max 1cm
R3 = 51Mega-Ohm - 1/2-1 watt
R4 = 3.9 Kilo-Ohm - 1/2-1 watt
R5 = 300 Kilo-Ohm - 3 watt
R6 = 270 Kilo-Ohm - 1/2-1 watt
R7 = 9.1 Kilo-Ohm - 1/2-1 watt
R8 = 51 Mega-Ohm - 1/2-1 watt
R9 = 1 Mega-Ohm - 1/2-1 watt
R10 = 1 Mega-Ohm - 1/2-1 watt
MIC Capacitors:
vC1 = 1000pf, 630v, 1cm lead space stretch to 1.5cm, max width 1.5 max height 1.5
C2 = 22NJ/223J, 0.022uF, 630v, lead space 1cm, width 1.2cm max 1.5cm
vC3 = 18pF, 420v
vC4 = 104J, 9mm lead space
vC5 = 100uF, 25v or above, 8mm diameter, 5mm lead space
vC6 = 1uF, 400v, 8mm diameter, 5mm lead space
C7 = 103J, 0.01uF, 450v, max width 1cm, 9mm lead space
vC8 = 1uF, 400v, 8mm diameter, 5mm lead space
C9 = 22NJ/223J, 0.022uF, 630v, lead space 1cm, width 1.2cm max 1.5cm
vC10 = 1uF, 400v, 8mm diameter, 5mm lead space
vC11 = 100uF, 25v or above, 8mm diameter, 5mm lead space
vC12 = 104J, 5mm lead space, width max 1.5cm
vC13 = 104J, 5mm lead space, width max 1.5cm
MIC Output Transistor housing: 25x40mm
MIC Output Transistor shape: Round
MIC Output Transistor nr: 5600
PSU Resistors:
R0 = Or,bl,bl,rd,br (2 watt min.)
R1 = Blu,Gr,Bl,Br,Br (2 watt min.)
R2 = Blu,Gr,Bl,Br,Br (2 watt min.)
R3 = Blu,Gr,Bl,Br,Br (2 watt min.)
R4 = Br,gr,bl,ye,br, (little unsure)
R5 = on the pattern dial, 4mm width, br,or,bl,or,br
R6 = on the pattern dial, 4mm width, br,or,bl,or,br
R7 = on the pattern dial, 4mm width, br,or,bl,or,br
R8 = on the pattern dial, 4mm width, br,or,bl,or,br
R9 = on the pattern dial, 4mm width, br,or,bl,or,br
R10 = on the pattern dial, 4mm width, br,or,bl,or,br
R11 = on the pattern dial, 4mm width, br,or,bl,or,br
R12 = on the pattern dial, 4mm width, br,or,bl,or,br
R13 = Rd,bl,bl,silv,br (2 watt min.)
R14 = or,bl,bl,or,br
R15 = gr,br,bl,re,br (tiny)
R16 = sl/gr,re,bl,bl,br tiny
R17 = or,bl,bl,or,br
R18 = or,bl,bl,or,br
R19 = re,vi,bl,re,br
PSU Relay:
  • Model: JQC-3F
  • Coil Voltage: 12VDC
  • Contact Ratings: 10A/240VAC, 12A/125VAC, 30VDC, 28VDC
PSU Capacitors:
C01 = 1uF, 400v, 8.5mm diam. room for bigger,
C1 = 47uF, 400v, 16mm diam., 2.5cm height max 5cm
C2 = 47uF, 400v, 16mm diam., 2.5cm height max 5cm
C3 = 47uF, 400v, 16mm diam., 2.5cm height max 5cm
C4 = 100uF, 250v, 16mm diam., 3cm height max 5cm
C5 = 220NJ, 400v, 1.8-2cm width,
C6 = 3300uF, 16v, 13mm diam., 2.5cm height max 5cm
C7 = 6800uF, 16v, 16mm diam., 3cm height max 5cm
C8 = 220uF, 25v, 8.5mm diam.,
C9 = 100uF, 16v, 5.2mm diam.,
C10 = 47uF, 25v 5.2mm diam.,
C11 = 103, no voltage written, tiny, 5mm lead space, plenty of space around and top
C12 = 1uF, 50v, 5.2mm diam.,
C13 = 1uF, 50v, 5.2mm diam.,
C14 = 104J, 60v, 8-10mm width,
CDial = 1uF, 400v
Ok, shame. Wish I could help.
Mine looks like it’s typical CCDA that can be found in just about any Chinese multi pattern tube mic. Which is a great thing :)
There are indeed similarities looking at the schematic, so surely it can be a help to have that as it is clearer!
As already mentioned, NO point in such a huge resistor there - 1/2 watt is more than enough.
I just wrote what is on the schematic in the lower left corner - other pictures I have seen have 2 watt in there, the z5600 schematic says 1 watt there, and Roadrunner also said 1 watt…
