Ahrue said:
Here's my mouser cart. This is my first DIY project, so I'm sure there are some things that may be wrong or may have better options. I used Gustav's "new GSSL" BOM from www.pcbgrinder.com and cross referenced it with the Giraf GSSL Part List.
http://www.mouser.com/ProjectManager/ProjectDetail.aspx?AccessID=9e1847fae5
The items below were either not in stock or I had no clue which item to put in the cart;
7 pcs ICsockets 8 pins
1 pcs ICsockets 14pins
3 pcs VCA sockets
3 pcs THAT2181B
2 pcs 5 way molex
1 pcs 10 way molex
2x15V secondaries power transformer
Fuse Holder
Fuse
Ill reply here instead of by mail.
Switches are not PCB compatible, I would replace those with the Lorlins. - http://se.mouser.com/Search/Refine.aspx?Keyword=lorlin+pcb+switch
I dont know those potentiometers, but the picture does not look like something I would use. - No time to check datasheets for their alpha pots now, but some 16mm alpha would be nice.
The 0,47 tantalum caps are SMD parts.
I did not check all resistors, and something might have gone under the radar.
Mouser is extremely slow for me now, so Ill post my searches instead of getting the direct link to the parts I found.
7 pcs ICsockets 8 pins - Search "dip8 socket"
1 pcs ICsockets 14pins (dip 14 socket)
3 pcs VCA sockets use half of a dip 14 for each. Not sure they have sil socket
3 pcs THAT2181B THAT VCA
2 pcs 5 way molex - dunno
1 pcs 10 way molex - dunno
2x15V secondaries power transformer -
Fuse Holder - panel fuse
Fuse - slow blow, I normally use a 500mA, but thats a little higher than actually needed.
Gustav
