Hi HerbertRHi, I found months ago somewhere in the web schematics, non working Gerbers...
have you builded it? or still looking for gerbers?
Hi, i never had any working Gerbers. But it is a cool projectHi HerbertR
>> HerbertR: Yer gonna need to re-output yer GERBER and N/C Drill files that are within your Post #1 ZIP file as they are fairly well HOSED!!! Here's just a very brief synopsis:Hi, I found months ago somewhere in the web schematics, non working Gerbers and a Layout of a 32C EQ of a Harrison Console. Does anyone know who designed them? I cannot find any informations? Does anyone know how to get the Gerbers working? The Layout and schematics look promising. Would be great if the Gerbers would work. But I have no experience in PCB designing...
Regards
[Must complete the upper board] -- 1) It appears as though -- neither -- of the PCBs that are shown here to be mounted to the "Mounting Cube" are actually/truly -- parallel -- with the "Mounting Cube" and, 2) Is there a reason with why you aren't using a normal "Pan-Head" machine-screw to hold the PCBs to the "Mounting Cube"? "Flat-Head" machine-screws are used for countersunk holes in sheet-metal. 3) I had come across a really cool -- 222MB CAD ZIP-file -- that contains the most fantastic 3D CAD-models, even in color, of every type, size and shape of capacitor, diode, IC-chip, PCB-mount heatsink, resistor, transistor, etc. that I normally would have shared with you, but.....well.....you know!!!Must complete the upper board... No spare time this period so i'm going very slow... Just assembled It to verify the mechanical part...
Hi Richiyobs. Cool project! Are you gonna share the docs?Must complete the upper board... No spare time this period so i'm going very slow... Just assembled It to verify the mechanical part...
Yes i'll share It as i finish and test the unit... Maybe on sunday a could complete soldering componentsHi Richiyobs. Cool project! Are you gonna share the docs?
Ip
[Attached how I redrawn it] -- You can display and show your schematics as being -- larger -- if you use the "landscape" mode of your "paper" orientation instead of using the "portrait" mode. In addition, if you have a -- Margins -- setting, you can also set it to 0.50" (12.7mm) instead of the usual 1.00" (25.4mm).Attached how I redrawn it...
