NP Elektroakustik
erik_DK
Århus Denmark
NP Elektroakustik was a small Danish company making audio solutions for among others DR, the National Danish Broadcast. Quality is at least on par with NTP, Tore Seem and the big famous German manufacturers. NP is often mistaken for NTP, a more well-known Danish company.
Most of the production was customer-specified mixing consoles, made as one-off products or in very small numbers. Getting documentation and manuals is extremely difficult, so please post anything, you may have.
/Erik
NP portable on-location mixer.
Full service manual for one of the very few mixers made in greater numbers.
  • NP - On Location Mixer_(Service manual w. schematics).pdf
    18.1 MB
NP IK36 Channel-strip (IK: short for "indgangs kanal" - input channel)
Far from complete, but the essential schematics are here
    1.6 MB
  • Indg. kanal IK36_blokdiagram.pdf
    88.7 KB
  • EQ.pdf
    163.9 KB
  • Mikrofonforstærker.pdf
    140.2 KB
  • Linie udg. forstærker.pdf
    97.7 KB
  • Linie indg. forstærker.pdf
    95.5 KB
  • Høj- og lavpas.pdf
    133.5 KB
NP IK42 channel-strip. Schematics and component overlay.
A good example of a channel for a large NP-desk.
It is built on a mainboard with all the knobs and dials. All functions are built as modules on the mainboard. Everything is there. You better print all the files and make your own complete manual.
If you ever come across a full mixer with this input channel, send me a PM. I have lots of files and you might be lucky, that there is something useable for you.
  • IK42 mainboard.pdf
    762.8 KB
  • IK42_phase_switch.pdf
    1.9 MB
  • IK42_insert_before_after_eq.pdf
    1.7 MB
  • IK42_insert_before_after_eq_component_overlay.pdf
    1.7 MB
  • IK42_electronically_balanced_input.pdf
    1.8 MB
  • IK42 zero_volt_stabilizer.pdf
    1.8 MB
  • IK42 Symmetric_buffer_LF 24.pdf
    1.7 MB
  • IK42 Symmetric_buffer_LF 24_component _overlay.pdf
    1.7 MB
  • IK42 relay_driver.pdf
    4.1 MB
  • IK42 mic_amp.pdf
    73.6 KB
  • IK42 Max_indicator.pdf
    1.8 MB
  • IK42 line_in.pdf
    2 MB
  • IK42 input_switch.pdf
    1.8 MB
  • IK42 Input_switch_for mic_ampLF 26.pdf
    4.1 MB
  • IK42 Input_switch_for mic_ampLF 26_component_overlay.pdf
    3.8 MB
  • IK42 input_and_insert_Page2.pdf
    2.4 MB
  • IK42 input_and_insert_Page1.pdf
    2.4 MB
  • IK42 Hi_n_lo_pass_Page-2.pdf
    1.7 MB
  • IK42 Hi_n_lo_pass_Page-1.pdf
    1.7 MB
  • IK42 Equalizer_page-3.pdf
    2.7 MB
  • IK42 Equalizer_page-2.pdf
    2.8 MB
  • IK42 Equalizer_page-1.pdf
    2.7 MB
  • IK42 Back-up_and_ reset_SF28_Page2.pdf
    4.1 MB
  • IK42 Back-up_and_ reset_SF28_Page1.pdf
    2 MB
  • IK42 Back-up_and_ reset_SF28_component_overlay.pdf
    4.7 MB
NP IK31 channel-strip Block diagram and component overlay.
Plus mic-line amp, filters and eq.
Interesting to see, that these three schematics are exactly the same as on the IK23 channel strip. An example of two designs that are mostly different in their physical lay-out. The IK31 has the gain controls for mic and line at the bottom right over the fader and the pan control on the top of the channel, where the IK 23 has the more normal lay-out with the gain controls on top of the channel and the pan control at the bottom right over the fader.
If you look at the block diagrams they show exactly the same pin-out for both channels, and the size and form of them are identical also.
  • NP_IK_31_a.pdf
    2.2 MB
  • NP_IK_31_b.pdf
    2.4 MB
  • NP_IK_31_bas diskant.pdf
    2.4 MB
  • NP_IK_31_comp. overlay_a.pdf
    2.7 MB
  • NP_IK_31_comp. overlay_b.pdf
    2.7 MB
  • NP_IK_31_comp. overlay_c.pdf
    2.6 MB
  • NP_IK_31_presense_absense_filter.pdf
    6.2 MB
  • NP_IK_31_mic-line-amp.pdf
    4.6 MB
  • NP_IK_31_Hi-lo-pass.pdf
    4.4 MB
NP IK06 channel strip
Complete set of schematics.
  • 1_Block_schem.pdf
    2.1 MB
  • 2_Overlay.pdf
    4 MB
  • 3_Mic_line_amp.pdf
    2.2 MB
  • 4_Hi_lo_filters.pdf
    2.4 MB
  • 5_Prescense_filter.pdf
    2.6 MB
  • 6_filter_buffer.pdf
    2.4 MB
  • 7_Cue_switch.pdf
    15.3 MB
  • 8_Output_stage.pdf
    15.5 MB
  • 9_Max_indicator.pdf
    2 MB
  • 10_Pan_and_outputs.pdf
    2.2 MB
NP IK23 channel strip
+ Schematics for power supply units
  • IK23_blokdiagram.pdf
    4.7 MB
  • IK23_comp_overlay.pdf
    6.9 MB
  • IK23_bas_disk.pdf
    6 MB
  • IK23_buffer_inverter.pdf
    16.9 MB
  • IK23_hi_low_pass.pdf
    4.4 MB
  • IK23_line_amp.pdf
    17 MB
  • IK23_mic_line_in.pdf
    4.6 MB
  • IK23_output_line_amp.pdf
    16.7 MB
  • IK23_overload_indicator.pdf
    16.6 MB
  • IK23_panorering.pdf
    5.5 MB
  • IK23_præs_abs.pdf
    6.2 MB
  • IK23_PSU_15_0_15.pdf
    5.8 MB
  • IK23_PSU_24_48.pdf
    3.8 MB
  • IK23_Aux_sends.pdf
    5.8 MB
NP channelstrip - unknown.
I don´t know which channelstrip, but the schematics belong together. It is an old one - the mic amp has the NTP M100 DOA instead of the later NP M99.
Far from complete.
Mar 03 2025 Update: This channel was part of a 24/8/2 console. Input channel had the code IK-A
  • NPxx_blokdigram.pdf
    5.6 MB
  • NPxx_Mic_line_amp.pdf
    5 MB
  • NPxx_monitor_1.pdf
    16.6 MB
  • NPxx_monitor_2.pdf
    17.2 MB
  • NPxx_Multifilter.pdf
    5.9 MB
NP microphone amp.
Old design running from a 24V power supply. Uses NTP M100 op-amps instead of the later NP M99
  • NPww_mikrofonforstærker.pdf
    17.5 MB
Hi Eric,
Thank you very much for your great effort to share interesting information with the community.
I wish you all the best.
Write your reply...
