GreyboxAudio
john12ax7 said:THAT 1646 is a dedicated output driver and is not compatible with a regular opamp. If you want simple and inexpensive the question becomes do you "need" a dedicated driver? If your circuit overall output is from an opamp, using an impedance balanced output is simple and effective.
Since you mentioned TL071, I would avoid using that for an output, as it doesn't have much drive capability.
The last stage of the EQ is the passive HPF and is loaded with 5,1k. So I guess an output stage with a lower impedance makes sense? But I got to admit, that I jumped head first into this project and my understanding of impedance/loading/driving is still lacking. I found an interesting overview of the different driving characteristics of different opamps in one of the apllication notes from Rane: https://www.rane.com/note126.html
I guess an NE553x would be more suited?
