SIAM 295b
MonoCutter was kind enough to send me some PCBs for testing and it worked out really well :) I've managed to add all the recent changes either by slightly modifiying the PCB or through the addition of a small daughter board. During testing I also spotted a small mistake in my schematics, which has now been corrected in Rev 05d.
    3.9 MB
The pcbs for krabbencutters REV 05d arrived and i couldn't wait to test them. The EQ worked as it should right from the first power up.
A next step will be to replace the pots with rotary switches. After that i would like to try different transformers.
Sometime in the future (after finishing all other projects :ROFLMAO:) there might be another revision of the pcb.
    1 MB
    1.1 MB
    70.5 KB
    95 KB
    117.5 KB
    139.2 KB
    150.9 KB
Update: I've renamed the repository https://github.com/greyboxaudio/SIAM-295b and the schematic has also been updated with some minor changes to the gyrators. I'm also happy to announce that I plan to design a PCB this year :)
I've been playing around with the circuit a bit more and I will try to replace the mid band with a matching state variable filter design. My current Q-mod implementation still feels too much like a hack for my taste and with an SVF design the Q will become fully variable. It would also reduce the total amount of opamps & film capacitors needed.
here are the built PCB's ,not completely populated for few parts here and there .. i didn't had 150uF at the moment ,i used whatever type of caps i could find ,not attempting to sound like the original
Nice! I love the visible DIY spirit. You can also use 100u + 47u in parallel for the high shelf, if you have those values at hand.
i bought 150uF ,these should be part of a mixer i am building 8 channels it's packed with features and i just hope it'll work
do you have the gerber
Thanks for making this module more widely available without inductors and all , i made a PCB layout for this and built 4 PCB's ,will test them these coming weeks
Hi do you have the gerber files ?
i can confirm that this is a working layout ,i don't know much about eq's ,it's a first eq i built ,i like it ,i just tested 2 of the 4 PCB's and they are working fine , now to wire the rest
thanks for the link, would you have some time to make a wiring diagram? there is little information on the pcb to understand the layout
best.
I have time ,just i have never made a wiring diagram so not sure where to start for that , i have Gimp i might try something not sure how it's gonna turn out ..those F1,F2 ...points are for the gyrators x 6 so that switch wires to the 4 position switch and that one to the midle pin of the Mid potentiometer , the other two pots are high and low ,the 3 points labeled switch are part of the cut/boost switch along with the point coming from the 150uF < that one connects to the pot i think it's high - control ,the other pot at the bottom left is for lows ,in the far right you have 4 pads for the 4 position switch as four positions and the one between 1K and the last 4M7 is the first postion of the 4 position switch the same one that connects to the 6 position switch centar ,and that's it
