shabtek said:
I am curious how this works.
Re: efficiency/power draw,
1 bottle is set up/biased to drive lowish Z--I think 10k load is fine.
If permanently driving very hiZ than idle current of 2nd stage is higher than needed.
You're right. I'll have to change the cathode resistor of the second stage to something more like 750Ω. The original design ran a little more current through the plate, but also seemed to load the plate unnecessarily. With a 10K load in parallel with the 22K plate resistor, the load is 6K8 (and actually lower if you take the feedback path into consideration). Seems to me like that would start to affect high frequencies.
As for the power supply - it's not as difficult as one would think. I can create all the voltages with two 24V transformers and a handful of other parts. The first (higher current) transformer creates the 24VDC, voltage doubler for phantom, and bipolar 12VDC. The second transformer steps the 24VAC back up to 240VAC, which give me my B+. I could run the filaments off of the +12VDC or create 6.3V from the 24V....
