Then the needed make up gain also will change!
I was looking into a passive system too but since I like to be able to insert outboards between the interface and the summing unit...
deArry, your diagram looks fine at a glance. Three positions (L, C, R) wouldn't be enough for my style of mixing; but if one insists on a balanced mix buss, it's tough to find 4-pole switches with many positions.
If I were making this, I think I'd add a resistor between each side of each mix bus and ground.
Was that in regards to what I posted or NYDs' echosendmxr.gif pic?
I'll come up with an attenuation value for those "in between" positions, if you like. Or if you prefer to do it yourself, I can give you the equations.
Whats that wierd blue cable.
Looks like 'remote controlled' switches, right ? / Whats that wierd blue cable
Where can you buy those switches?
