Mikael-ange
Active member
Ok so heater is correct (off course you mesure it with one probe of you multimeter on pin 4 in your case, and the other on a ground plane like the support rail of the mic for exemple.).
And btw your tube pinout seem correct.
Now as far as b+ and bias go, you mesure it at the psu, and adjust it with the mic connected.
I saying that because you mention b+ 120v unloaded.
Now for the transformer, xp1 and xp2 are your primary (xp1 is audio + and xp2 is audio -).
The secondery side go to the xlr.
Have you mesured what side is the primary and what side is the secondery btw?
I know stupid question but just to be sure.
