Matador
Reverend said:Ok. But, with the stock Alcatron capsule and a good 6025 tube, turning the B+ trimmer still does nothing to the voltage. Is this a problem?
Another question. I'm getting hum when I listen. When I touch the top of the capsule or another part, the hum goes away, but I can't hear the capsule. Could I have a problem? Could it be the same problem with a cap (C10 or C13?) as described in earlier posts?
Sorry. Ha Ha. Chunger calls himself a newbie....I'm the real deal!
Ok let's tackle these one at a time:
1) Please remove the mike from the equation. Unplug it from the PSU, then place a 180K resistor across the B+ and ground connections. You can stick the leads right in the 7-pin XLR connector and then fire up the PSU. Is the B+ adjustable? If so, you have problems in the mike (leading to part 2).
2) Per my previous post:
Matador said:It sounds like a grounding issue to me.
Please confirm the following:
1) On your 7-pin XLR connector into the mike, that you have whatever wire is carrying ground also bridges over to the brass lug that connects with the XLR screw. You can clearly see it in Chunger's build pic:
2) That you "loosened" the XLR screw which actually tightens it against the bottom housing.
If you don't have a solid ground path in the mike, then the tube will not draw any current, and thus the B+ will sit high and appear to have little adjustment. Make sure you have less than 1 ohm resistance between the ground lug in the PSU (pin5 of the 5-pin PSU connector, labeled "P8" I think) and everywhere inside the mike with everything plugged in (POWER OFF!!!!!!) and the outer tube sleeve removed.
The fact that you have hum changes when you touch the parts leads me to believe you have a bum ground path.
