Matador
jplebre said:Guys, quick question.
I'm trying to understand what Chunger is trying to achieve when he wired 2 cables to one of the backplates and then to FB and RB on the PCB.
I may have misunderstood the drawing.
He also says it's optional.
right now, I have the front "back" plate wired to FB. do I need to jump FB to RB or do I need to run a second cable from RB (capsule) to RB (PCB)?
.... am I making sense?
It's an either/or thing. You can bridge the FB and RB right at the capsule (the preferred way), or you can bridge them at the PCB. Bridging in both places neither helps nor hurts. If you have a capsule with a single backplate you don't have to run two wires, and you can bridge them right at the PCB.
I debated making them a single PCB connection but figured people wanted the connections as close to the original as possible.
