Hi guys
the mic is alive and sounding stunning, even with the stock alctron capsule.
I'm hoping with the more accurate edge terminated capsules that cheap feeling on the transients will get improved
I have a few questions, I'm not sure if this is normal:
- with no body cover on, the microphone is incredibly hum-y. Enough to bury signal (if signal is spoken words, low level singing).
- With body cover on, mic is spotless clean!
I know some members mentioned hum problems and other people answered to put the body on, but I still feel it's weird there's SO MUCH hum without the cover.
- the voltage takes a while to ramp up to 120v (a few minutes at least) and takes a very long time to ramp down (+10min).
in fact, the mic stays "operational" for 2-3min before start loosing signal.
Is this normal? I'm used to seeing bleed resistors on PSU designs but not on this one, so I'm unsure if it's normal.
(I don't think R6 - 470kOhm qualifies as bleeding resistor?)
- Bias: I'm using a fluke 175 but I'm not sure I'm measuring Bias accurately. Every time I probe P-ground and P-Bias, the voltage shown is lower (-1.3/-1.5v) and creeps up to -1v where I've set it previously. Is this normal? if so, should I aim for the DMM-free voltage or loaded by the DMM?
If it's not normal, any ideas?
- there's a windy sound but I'm 100% sure it's my room and windows and computer and etc. I'm in the studio 3 days this week so I'll be able to try that out.
If you have rumble and hiss noises, try ditching the stock altron capsule. even a £10 EH6072 is free of most of those issues and sounds quite acceptable.
