DDay said:Yes I saw it on the PCB, it's just strange C12 isn't in the BOM (http://www.musicalsparks.com/images/c12/c12_bom.pdf) but I guess neither is the output transformer or capsule. Thanks for the heads up on using an MP.
Matador said:DDay said:Yes I saw it on the PCB, it's just strange C12 isn't in the BOM (http://www.musicalsparks.com/images/c12/c12_bom.pdf) but I guess neither is the output transformer or capsule. Thanks for the heads up on using an MP.
Wow, I can't believe I left that one off.I have a new version of the BOM, but have been too busy (aka. too lazy) to upload it.
Also, to answer the "don't use polyprop for C12...": it's like saying don't put salt on your food.Many have built with the Erse polyprop in C12 and have been very happy. I suggest you try out a few and pick the one that sounds best to you, and they aren't too expensive so you can try several. Also try several values: a few have stuffed up to 2uF for C12 with good results.
DDay said:Cool, thanks Matador. Any chance you could put the lorlin rotary switch in there as well, not sure the correct one to get.
patterson said:I would be interested in seeing if there is a difference with a MP cap. Is there anyone who has a source for these? the C-12 cap in the kit is over 600v. rated. What would be the minimum reasonable voltage rating.
patterson said:Is there anyone who has a source for these?
DDay said:Also is it ok to use a wire jumper instead of the SMT zero resistor?
Matador said:Bah Chunger posted before I could get to the PSU part. :-[
12AT7 Conversion - The PSU
So the two big changes from above (from the PSU perspective) are: a) the idle bias current draw increases from 0.7mA to 1.1mA, and b) the "cathode" resistance decreases from 1.4K down to 900ohms. "B" is not an issue because we have R3 which can easily accommodate this change. With the default 91K values of R1 and R2, the additional 0.4mA of current will drop cause an additional 72V drop in B+, which means there would be no way to get 120V out of the PSU. So some re-calculations are in order.
Let's assume that R4 is set for half, which is 50K. We have about 270V coming out of the rectifier diodes and we want 120V out of the PSU, which is a 150V drop across R1+R2+R4. Total current should be 1.1mA + 0.25mA (through R6) which is 1.35mA. 150V drop at 1.35mA implies a total resistance of 112K. Since R4 provides 50K, then R1+R2 needs to equal about 62K. R1 = R2 = 33K sounds pretty good to me. This gives an adjustment range of about 160V down to about 50V.
12AT7 Conversion - Summary
Microphone: Change R17 from 100K down to 47K
PSU: Drop R1 and R2 down to 33K. Adjust R3 down to about 900ohms, then tweak with the actual tube.
Test load: decreases from 180K down to (120V/1.35mA) = 88K. 91K would work as a substitute for a real tube for PSU testing.
Just wanted to thank-you and kudos to you LN76 because you always provide such interesting and well-thought out ideas! Thanks for being such a great asset to this community.ln76d said:Matador said:DDay said:Yes I saw it on the PCB, it's just strange C12 isn't in the BOM (http://www.musicalsparks.com/images/c12/c12_bom.pdf) but I guess neither is the output transformer or capsule. Thanks for the heads up on using an MP.
It happens. I made once album graphics for CD release where two songs titles were in different order and it was released that waysh*t happens
About the polypropylene - of course it's an obvious oversimplification![]()
From the other hand most people will find "use polypropylene only" type information.
Someone which want to build microphones not only because it's cheaper and he "have to", to get tool only - will probably use his brain and look for his own way
Many people are here to build few things and bye then - so they wouldn't look for anything more.
My - Don't use MKP/polypropylene at the output! - is for those lazy guys which will probably choose between use or not use
Testing parts is one of the most important things - so of course i subscribe at that with both hands!
My beloved method is rotary switch with few capacitors and making A/B comparison by listening and measurement (if possible).
From my experience, especially with small sized transformers, oversized capacitors and polypropylene (tested many from chinese to audiophile market parts) overall sound worse - it's not even related with low end response and its corner but full usable spectrum. Best option which i found (whatever type of microphone it's) are MP caps - and this is not related to any historical things. Of course you can find some MP which will degrade the sound due to out of specs - which is related with the age of these parts.
digitall2000 said:I'm trying to fiure out what is need to calculate the actual tube circuit load so as to figure a load resistor for testing the PSU
